hotcam stage 2
you'll gain power, but will only go as fast as ur gearing will let you, if ur tappin the limiter now in 5th, you wont gain any top end speed
With a 14t sprocket like you have on the front of yours my GPS read 84.3mph topped all the way out. My bike still has the factory jetting and exhaust. I was tucked down in as far as I could get and ran a little over 1/4mile. I may weigh less than you at 160-165lbs but I think with a full exhaust like you have, you should atleast be able to obtain the same speed that I am.
You are right however that you arent even close to hitting the rev-limiter. It kicks in at 9000rpm and at 84mph Im only at like 77-7800rpm. With stock gearing, if the raptor were able to reach the rev-limiter in 5th gear, it would do approximatley 91mph.
Elkaholic
Sep 6, 2015 02:44 PM
