Tach on a 2000
Old Jun 9, 2006 | 11:07 AM
MRDS650's Avatar
Canadian and Proud of it !!!
Default Tach on a 2000
I am in the process of buying a tach for my 2000 DS650. I know in the later years they were factory on the Baja, so the wiring harness was there and they would plug right in.
Will the harness be there on my 2000 or will I have to wire it in ???
Old Jun 9, 2006 | 09:45 PM
ScoobyDFW's Avatar
which tach are you going to buy?
maybe this one is for the old style wiring harness (non-Baja): http://www.parkeryamaha.com/index.as...D&ProdID=22225
Old Jun 9, 2006 | 10:21 PM
Majorecho's Avatar
there's not much involved with hooking a tach up, you'll need to splice into a switched 12v( near the key) you'll need to pick up a signal from one of the coils and you'll need a ground, that's about it, The tach I installed on my 2000 was from RWR and came with the connectors and a little diagram and was very straigh forward- they are nice to have
have fun.
Old Jun 10, 2006 | 02:18 PM
MRDS650's Avatar
The one I bought is the one you have listed.
Bought it from Rexburg motorsparts for $145.00
So it should easy to install right ???
Plan on installing it in the dunes when I am in St. A's
Do you guys know what size of hole saw I will need for the dash ???
Old Jun 11, 2006 | 12:38 AM
matts01ds650's Avatar
do you have to buy an expensive atv tach or will anything work?
Old Jun 11, 2006 | 04:58 PM
ScoobyDFW's Avatar
you can't use automotive tachs on the DS. you need a tach that is designed for a CDI ignition.
here are some gauges: http://forums.atvconnection.com/mess...hreadid=489583
Old Jun 12, 2006 | 01:45 AM
MrMeaner's Avatar
Old Jun 12, 2006 | 10:28 AM
MRDS650's Avatar
Anybody know what size of hole saw I should buy to cut the hole in the dash ????
Old Jun 12, 2006 | 07:51 PM
BioWare's Avatar
Toxic Ryder
I just used the rotozip, works very nice.
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Logan Collins
Sep 5, 2015 08:03 PM
