INDEPENDANT SUSPENSION
Old Jun 11, 2006 | 12:28 AM
scooter1967's Avatar
Default INDEPENDANT SUSPENSION
was wondering if there is a way to stiffen up the independant suspension on the '06 500 efi polaris???
i hook up a small trailer for working and........man it logs down. i also no longer have the ground clearance anymore either.
let me know
Old Jun 11, 2006 | 12:41 AM
okiedude's Avatar
Stiffer springs
Old Jun 11, 2006 | 12:49 AM
workaholic's Avatar
The rear shocks are adjustable to allow for heavier tungue loads. Consult your manual for adjustment prcedures
Mark
Old Jun 11, 2006 | 12:59 AM
Fireslayer's Avatar
Scooter, There is adjusters on the rear shocks to increase the spring pre-load and stiffen up the rear. My "06" 700EFI came from the factory set in the softest position. It takes a spanner type wrench to adjust the shocks. You might be able to find one that will work at your local hardware store, or run it by the dealer and have him turn them up for you. If it still isn't stiff enough then the next option would be to change to heavier springs. Polaris,EPI,Speedwerx and others produce stiffer replacement springs if needed. Try the adjustment on the stockers first, because it does stiffen the rear somewhat. There are 5 positions to choose from counting the one they are now set in.
spyder6's Avatar
adjusting your springs is really easy. ive found it best to lift the rear end of hte quad off the ground to rid them of tension. get out the tool that came in your tool pack that looks like a black Sickle. there will be studded machined ring on the bottom side of the spring rotate it upwards (compressing the spring) and lock it down when you get to your desired tension. then lower the quad back down and try it out. if this ends up no working, a set of Sportsman MV rear springs would do the trick, i think there about 90 bucks
Old Jun 11, 2006 | 01:08 AM
thanks alot all...sounds good
Old Jun 11, 2006 | 01:09 AM
Fireslayer's Avatar
Spyder, I just went and checked my toolkit and didn't find a shock spanner wrench.They may not put them in the Sportsman toolkits. Either that or Polaris failed to send one with my machine, as I pulled it from the crate myself and helped set it up. Say they did include one with your Predator?
Old Jun 11, 2006 | 01:11 AM
spyder6's Avatar
i got one with my Sportsman 500, one with my Sportsman 800, and one with my Predator. so i have 3. i kind of failed to give my tool kit back to the dealer when i traded my 800 in for my preddy [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jun 11, 2006 | 01:16 AM
Fireslayer's Avatar
Yep, now I know who got "my" spanner wrench.LOL.
Old Jun 11, 2006 | 01:19 AM
spyder6's Avatar
haha, all it is, is a stamped peice of metal that looks just like a Sickle and painted in some cheap *** black paint. most of the paint is worn off of mine that came with my predator, and i only adjusted my shocks twice. seems like they could teflon coat it or something so it would last.
