400 Scrambler Cooling problem
Old Jun 12, 2006 | 12:50 AM
scramser's Avatar
Default 400 Scrambler Cooling problem
Do these motors have a thermostat to control water flow? If so where? I add coolant to mine and it pumps it out the overflow bottle. I am thinking thermostat, water pump, or head gasket. Radiator is clean and does not get very hot. Anyone have this happen to them, please help. Thanks....................Brian
Old Jun 12, 2006 | 07:33 PM
ftwflh's Avatar
Check the headgasket first.Then check the counterbalance for antifreeze,water pump could be bad.
Old Jun 12, 2006 | 10:22 PM
scramser's Avatar
No coolent in the counerbalance oil. Over heat light never comes on. Pumped cooling system up to 25 pounds and it held that for over two hours. I have a leak down tester for cyl. pressure. I may have to use that on it to see. I am pulling the motor apart soon as I have a ported cyl to put on it. Does anyone know if these motors have a thermostat?..................Brian
Old Jun 12, 2006 | 10:39 PM
Jayblazer's Avatar
there is a heat sensor on top of the head there is also a screw there to bleed off air in your coolant system...
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
clsharky
Jul 13, 2015 02:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Chocobamofo
Jul 10, 2015 07:46 PM
