Does a brute have too much power
Old Jun 12, 2006 | 07:22 PM
Bigrizz's Avatar
Default Does a brute have too much power
My friend has a brute force 750, he just took it back to the dealer because it has twisted the rear differential off the frame on one side. The dealer said they have never seen this before. I was woundering has any one has had or heard of this happening.
Old Jun 13, 2006 | 04:51 PM
MadLT's Avatar
This is not normally a problem, but I have commonly heard of loose mounting bolts causing problems.
Old Jun 13, 2006 | 05:20 PM
blackknight's Avatar
may b so the brute can give you MONKEY arms lol.check motor mount bolts at lest one a week .i give mine a good check up at lest once a month all bolts .tie rod ends befour each ride just to b sure .o and lug nuts had mine into the dealer the other day to set the belt figured i,d get him to check front brakes while it was there ,he forgot to tightin the lug nuts AAAAAAA they where only hand tight lucky i check things befour i ride
MeadowlarkFarm
Nov 27, 2019 08:40 PM
ylomnstr
Sep 22, 2015 12:19 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
ylomnstr
Sep 4, 2015 05:02 PM
