Banshee carb help
Old Jun 13, 2006 | 01:46 PM
mackshee's Avatar
Default Banshee carb help
I need a little carb help on my banshee. I have stock pipes aftermarket reeds, K&N air filter,and a boost bottle. I have a #25 pilot jet and a #300 main. And im having problems with it bogging at lower rpms can any give me some tips on tuning it in a little better.
Old Jun 13, 2006 | 03:50 PM
MITTY26's Avatar
Those mains are to rich for your setup.
Old Jun 13, 2006 | 04:34 PM
mackshee's Avatar
Thanks any idea on what my jetting should be
Old Jun 13, 2006 | 04:38 PM
lildeezul's Avatar
He is totaly wrong, if you bogggin at low rpm's that isnt the main jet, if you are bogging at high rpm's then yeah its ur main.
but since ur boggin at low rpm's it means, your pilot jet is to rich. or your pilot air screw, lean up the pilot air screw NOT THE PILOT JET, turn the screw to the left to lean it up, and see how it runs.
Old Jun 13, 2006 | 05:07 PM
mackshee's Avatar
Thanks i tried that then it would'nt start unless i turned the idle screws out. Any ideas on what could be causing that?
Old Jun 18, 2006 | 01:46 PM
MITTY26's Avatar
Those mains are way to fat . You have stock pipes with a k&n , the reeds don't effect jetting that much (if any at all) . Banshees come with a 200 main from factory with STOCK pipes , so okay you added a filter so maybe jump up a size in the mains so now you should be at a 210 main. 300 mains are more for a piped banshee with a filter running at some altitude. But those 300 mains you got with a stock setup and a filter would work very well at say 4000 ft BELOW sea level , and you know that is not possible. Yes the main mainly effects WOT but the needle does not 100 % plug off the main jet when you are at slower rpm's or at little throttle pull.
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
