Grizzly clutch kit vs kodiak 400 clutch weights
Old Jun 13, 2006 | 07:54 PM
Hebs's Avatar
Default Grizzly clutch kit vs kodiak 400 clutch weights
Ok... I'm looking into installing a clutch kit on my 06 grizzly... I've had 1 guy say that I should put the kodiak 400 clutch weights on my grizz, and this will gimme a couple hundred or so RPMs at the bottom end.
Has anyone done either? How well does your clutch kit work?
Have you seen the kodiak 400 clutch weights mod? Is it better? What about reliability?
thanks...
Old Jun 13, 2006 | 09:24 PM
OGGYDOGGY's Avatar
Not saying that you are wrong, but I heard it was weights out of the 600 Griz weights that you need to use , somebuddy correct me if im wrong. I actually tried and did not really notice a diff . but im not tached so ,I couldnt really be sure.
Old Jun 13, 2006 | 09:40 PM
Hebs's Avatar
nah... he specifically said the kodiak 400... not to be confused w/ the kodiak 450...
Old Jun 14, 2006 | 03:17 PM
hondabuster's Avatar
Theres alot more to clutching and clutch kits than just the rollers.
Yes, using the weights from the 400, will delay the engagement, and make the motor rev a bit higher before the tranny starts to pull. But youll also notice the backshifting isnt gonna be what it used to be, and top end will suffer as well. Theres a tradeoff in everything which gets modified.
Clutch kits come with lighter rollers, and a new secondary spring,(to fix the backshifting /top end issues), and new heavier springs, for the centrifical clutch, which raises the rpms higher before engagement.
Its kind of like jetting, its a package deal, or things dont work right. All three need to be modified, or you probably wont like the results. It certainly wont hurt to try, and if you like it, to leave them in there.
Sent a pm
RedRancher
Oct 15, 2020 01:45 PM
mitchxc700
Aug 19, 2015 02:41 AM
Cantbuytime
Aug 17, 2015 06:33 PM
Jul 28, 2015 12:12 PM
Mikesohio
Jul 26, 2015 10:51 AM
