Performance exhaust
Old Jun 13, 2006 | 09:56 PM
cvc42's Avatar
Default Performance exhaust
Can some one tell what a performance exhuast is. What is the difference between it and a stock pipe? And where could i get one for my Marshin 150cc ATV. It has the same motor as the Redcats, Yamoto ect.
Thanks
Old Jun 15, 2006 | 01:17 AM
sssduane's Avatar
A performace exhaust will typically enhance power at a rpm range, or ranges, being low, middle and top end. Basically a performance exhaust will open up and allow more air flow from the engine, but you also have to be able to let more air into the engine, which usually requires a different carb or sometimes just a different air box/filter housing.
As far as an exhaust for that ATV, can't help you.
Old Jun 15, 2006 | 07:53 PM
atvmike92's Avatar
Theoffroadoutlet.com has exhaust systems. Their number is on the homepage. And mywifesquad said hes got an answer pipe on a yamoto 150. Trying to find out where to get
it right now.
Old Jun 15, 2006 | 08:20 PM
cvc42's Avatar
How much of a differance do they make, if you find out let me know.
thanks!
Old Jun 15, 2006 | 08:32 PM
atvmike92's Avatar
In an earlier raceway forum I found out about someone whos tried the pipe on a 110 150 and
250. he said they sound really good and the power is great. The price is $250 for the
complete exhaust system.
Old Jun 17, 2006 | 02:22 AM
oldyeller's Avatar
A tuned pipe on a two stroke engine can make a huge difference in power...A performance exhaust system on a 4 stroke usually doesn't give you that much of a gain unless the stock system was really restrictive and you combine it with intake mods like sssduane talked about...Don't be fooled by thinking your making more power just because it "sounds" better.
Old Jun 17, 2006 | 08:16 PM
atvmike92's Avatar
The 150 atvs do have restrictive baffles in them. So the increase is probably more noticeable.
Old Jun 18, 2006 | 12:27 AM
cvc42's Avatar
OK dumb ? why do they put restrictors in them?
Old Jun 18, 2006 | 11:11 AM
atvmike92's Avatar
i dont know why they do that. On the polaris 200 phoenix, they have a baffle too. I think they
only do this restrictive stuff on smaller atvs.
Old Jun 18, 2006 | 04:11 PM
XxBamBam2xX's Avatar
sssduane is right performance gives you more power to the quad some people perfer aftermarket or performane axhaust and some people just like it plain and simple stock
