Bleeding Oil system
Old Jun 16, 2006 | 11:14 AM
rajaa11's Avatar
Default Bleeding Oil system
Hello, have anyone ever bleed there oil system? if so how do you get the pressure bleeding screw off? seem like it will not come off, Dont want to strip the slots out
Old Jun 16, 2006 | 10:37 PM
crazeejames's Avatar
Hey Rajaa11, I had the same problem, I tried every wide blade screwdriver I had and pretty much just kept rounding out the slot. Went to town and bought a "hand impact driver", basically its a 10-20 dollar tool with 4 bits, you just put on the bit you need(slot in this case)hold it tight to the screw and bang the back with a hammer, it twists as you hit it, and bango the screw comes loose. They are really useful tools, you'll find other uses if you buy one! It only took me one light hit with the hammer and mine came loose, saved alot of stress from before with watching screwdrivers slip out of the slot!!!!
Once you get it loose, just leave your kill switch in off position and spin your motor till oil pumps out of the bleed hole.
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
