1990 TRX300 fuel problems
Old Jun 18, 2006 | 07:23 PM
sdgundog's Avatar
Default 1990 TRX300 fuel problems
I have a 1990 TRX300 4trax that is in cherry condition. It has been in storage for the past year and I brought it home for a little fun. I changed the battery and it fire up right away and ran a little rough. I decided to drain off the old gas by pulling the line between the tank valve and the carb. After adding fresh gas I cannot get the engine to run. I did cheat and tried a little starter fluid and it would fire and die. Here is what I've checked:
1) Fuel tank valve is open a flows.
2) Gas tank cap valve is in the "on" position.
3) The primer is a little stiff and I did get a drop of gas from the primer area when I pushed it pretty hard.
4) Air filter cleaned.
5) Couldn't find the fuel strainer/filter. The manual show a fuel line exiting the tank valve straight down and the strainer following the valve. My fuel line exits from a 3 o'clock position and attaches using a nipple.
What am I missing? Any thoughts or suggestions would be appreciated!
sdgundog
Old Jun 18, 2006 | 10:39 PM
Mr450Cooper's Avatar
take the carb off and take the float bowl off you jets are clogged take all the jets out and clean them and it will fire right up
Cooper
Old Jun 18, 2006 | 11:49 PM
sdgundog's Avatar
Cooper, I'll give it a try. Thanks
Old Jun 19, 2006 | 03:03 AM
fasterthanyou22's Avatar
Oh yea, your float is coated with crap gas crystals. Just do as he said and take it off and clean it out and clean the jets and everything, make sure every crystal is out of there before putting it back together.
Old Jun 26, 2006 | 12:34 AM
Tuscarora's Avatar
On my 91 the fuel exits at 3 Oclock but the strainer is below the valve at 6 Oclock. I dont have the bike here now but it seems like I used a 10mm to unscrew the thing and pulled the screen straight down out of the valve.
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
