? on 350 fourtrax 4x4
Old Nov 25, 2000 | 09:13 PM
Mudskipper's Avatar
Just bought and have no manual.
Oil capacity ?
plug gap?
any tricks to make it as trail friendly as possible etc.
Old Nov 25, 2000 | 10:23 PM
Farmr123's Avatar
Oil capacity...roughly 2 1/2 quarts, maybe more with filter change
Plug gap...not sure...best guess .035"
Tips:
Mainly watch the CV joint boots. Everything else seems bulletproof unless you drive like a maniac.
If the battery seems to be getting weak, clean all the connections, my 300 is notorious for that. Nothing is actually broken, just dirty connections. Dielectric grease helps.
Old Nov 25, 2000 | 11:44 PM
Mudskipper's Avatar
Thanks farmr.
Just ordered some black waters, one size up as the there seems to be plenty of torque. Can't see as much can be done to the susp. We play hard so maybe this won't be the best choice (ATV) I know they have a great rep. as far as being tough. Will just treat rough without being abusive
Old Nov 27, 2000 | 11:14 AM
Farmr123's Avatar
One more thing, if you got it used, you might want to check the clutch adjustment. If you want to know the setting, I can look it up for you.
Old Nov 28, 2000 | 09:09 AM
davearm's Avatar
You may want to try starting with two quarts even with a filter. The filter is the Honda standard found on the Big Red and 300. With the front swingarm setup the CV boots are pretty protected.
If the suspension rough now with stock tires, the Blackwaters will be murder. You could skid timber with that Honda with Blackwaters. The only thing I found to help with the ride was Motrin before and after a day of riding.
Dave Armbruster '97 Wolverine
(old body just couldn't take the TRX350 ride anymore)
Old Dec 3, 2000 | 12:03 AM
Aquaman's Avatar
what year is it?
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
ScopeZ_
Jul 28, 2015 01:44 AM
