Yamaha Raptor Clutch slipping
Old Jun 21, 2006 | 04:18 PM
hondakilla4336's Avatar
Default Yamaha Raptor Clutch slipping
The last two weekends i have been to the track and noticed my clutch was slipping horribly.....soo i figured id change to a better oil and it would take care of it.. well i put some cheep oil in with the cleaner and ran it for about 10 minutes then drained it out.. and put all yama lube in..it helped very little but very soon after it was slipping jsut as bad... should i buy a new clutch and if soo wich one...
by the way i have a 01 raptor
Old Jun 21, 2006 | 11:33 PM
Raptor149's Avatar
hopefully it's just your clutch. in that case, spend $120 and get the GYT-R replacement clutch plates and springs. don't forget to buy a new gasket, too.
But, seeing that you have an '01 Raptor, if you haven't heard this already then I'm about to give you some bad news. The '01 Raptors had some serious transmission issues, which often resulted in failure and detonation to the gears. Alba sells an upgrade for the transmission for around $600.
I don't know that it is your transmission going, but it is a possibility with your model year. Look into it further. If it is an '01 and the plates have never been replaced, then you do need new clutch plates also. But find out if it is your transmission before you do any further damage, and buy the upgrade.
Old Jun 22, 2006 | 08:49 PM
yeah i knew about the transmission problems... but this 01 wasnt even fired up until 03.... the guy who baught it accually broke his back before he got to ride it and... it sat in his garage until 2003 when i bought it.....soo i hope its not the tranny.... well i bought a new clutch.. its the OEM magnum... but i dont even know where to begin with the instalation.....like the water pump and oil pump are connected to the case right??? soo i have to drain all that and do whatever else..... could you tell me a breif order of how to remove the case because the manual is S**T..
Old Jun 25, 2006 | 11:46 PM
Raptor149's Avatar
you need to buy a Yamaha shop manual at the least (about $65 at your dealer) or a good Clymer manual. But I'll do my best from memory:
Obviously, first drain the oil. Then drain the coolant.
Remove the coolant hoses from the water pump. Detach the clutch from the cable retention clamp and from the actuator arm where the cable connects.
You're also going to have to remove your brake lever and your right footpeg. Nerf bars if you've got 'em.
Then remove the water pump housing and finally the pump.
Then it should just be the case, which is a pain. You're going to have some difficulty lining things up when you put the case back on, not to mention the clutch stack itself. You need to go buy a manual before you do anything, but you may be able to find some links on this site with images and further instruction.
ghost civic
Jul 15, 2015 10:48 PM
black_thunder
Jul 12, 2015 11:04 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
