Intake valve ?
Old Jun 21, 2006 | 07:48 PM
atvaddict01's Avatar
Default Intake valve ?
All my other gaps were good.My right side intake had no clearance.Why?Is there any possible
problems i should watch out for?
Thanks for the help on this ? and all the info you have all taken the time to post.Without it i
would not of had the ***** to try my own valve adjustment.
Old Jun 22, 2006 | 12:07 PM
BigDaddy331's Avatar
If it's a motor that is pretty much factor fresh, the seat cold have been installed a little deep. Definitely make it right according to spec, and move on. Check it after a ride or two.... my guess is that you'll be fine. Did you put cams in or something? If you did, and are not just checking gaps, then there might be a problem. Take the cams out and make DOUBLE SURE there is nothing holding in the cam journal. I had a set of cams one that could not, for the life of me, get in right. Wouldn't turn with the tray locked down, had no clearance etc. etc. after about 4 take-outs and re-installs, I found a small piece of flashing on the journal. Made me mad, but I was glad I found it..... Everything went in like a champ after.
Somethng to check anyway....
Good luck
Old Jun 23, 2006 | 05:39 AM
Thanks bigdaddy everything is stock.Just curios thats all.
Old Jun 23, 2006 | 03:26 PM
SW2steve77's Avatar
I just did my valves too......If your looking at it standing at the rear looking at the front of the bike. I noticed that the exhaust right side was wore. .006 fit but a .007 didn't. The other exhaust looked good and the right intake looked good too, but the left intake was tight, .003 fit but a .004 didn't. Does that sound about right??
Old Jun 23, 2006 | 08:15 PM
Left front was .004
Right front was .006
Left rear was 0
right rear was .005
The left rear is now .004
And the rest are the same.
Thanks again guys for all the info.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
