Just bought new Baja 90 bogs at 18 km/hr
Old Jun 26, 2006 | 11:01 PM
Nonothing's Avatar
Default Just bought new Baja 90 bogs at 18 km/hr
Hi I'm new to asian bikes and if this question has been asked before sorry up front.
I just bought it for my son's birthday and as usual at the last minute.
Here is what I have done I did a search and read several posts by 2manytoys and I followed his instructions:
1. I changed the oil first thing
2. Ran the bike for 40 minutes idling ( adjusted idle up just a bit cause it stalled at first)
3. Shut it down and had supper and a couple of beer (1 hour)
4. Ran it again and drove it adn at 18 km/hr it bogs bad and as I lift the throttle it pick up to about 23 km/hr and then bogs again
5. put tape over half of air intake and still exact thing happens so it isn't lean right???
Can anyone shed some light please
Old Jun 26, 2006 | 11:10 PM
hoytultratec's Avatar
take the tape off intake, first thing take carb off and clean with carb cleaner and blow it all out try that first.
hoyt
Old Jun 26, 2006 | 11:33 PM
cvc42's Avatar
Pull out the Main jet, and remove the needle jet and blow out with air, there is alot of crap in the new carbs...
Old Jun 27, 2006 | 12:04 AM
Nonothing's Avatar
both sound agressive to start with a brand new unit but like I said I am new to these units but I will try main jet thing first thanks guys
Anybody know where to get a good service manual for these the manual that comes with it tells you very little
Old Jun 27, 2006 | 12:49 AM
keist08's Avatar
sounds to me like you have a clogged jet get some carb cleaner and take spray it in all holes. shell run
Old Jun 27, 2006 | 06:07 PM
its amazing what a little crap from the tank will do to a carb even though its brand new you wont even see the stuff in the carb its not hard to pull off and clean it right , it will most likely run right after this this is all good advice on here, probably because we all had to do it too.
good luck
hoyt
Old Jun 27, 2006 | 08:58 PM
Nonothing's Avatar
Well thanks for all the advice guys
I just sprayed some carb cleaner in it and ran it for a while and I just got 52 km/hr out of her with my 180 lbs on it
Thanks again
scram5050
Aug 30, 2024 01:39 PM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
ghost civic
Jul 27, 2015 03:15 AM
