baja 90 help
Old Jun 28, 2006 | 12:34 PM
bajakid13's Avatar
Default baja 90 help
hey im new to the forums and i have a baja 90 and a yahamaha banshee but my 90cc has a problem the chain is extremly loose and does any one here no how to tighten a chain if so plese post how to do so. thanks guys im lovin the forums
does anyone know where to get tires for the baja90cc
Old Jul 6, 2006 | 10:50 AM
DANVAN's Avatar
There are 4 bolts that u have to loosen, down at the rear axle area, I think there 17mm, then there is the adjusting bolt dead center in the axle,on the under side, loosed the locking nut, tighten the bolt untill the chain has the proper tention, then tighten the locking nut and the original 4 nuts.
When u loosen the 1st 4 bolts, on mine, I had to hold the small 13mm on the opposite side of the nut, they were spinning, hope this helps.
akguy31
Aug 31, 2019 04:34 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Jul 30, 2015 09:39 AM
