what color wire?
Old Jun 29, 2006 | 05:50 PM
mybrute's Avatar
Default what color wire?
I just got my Venom winch 3000lb and I was curious about which color wire are you suppose to tie into. Also where did you mount your contactor. I have a 06 BF 750i. Thanks for your help.
Old Jun 29, 2006 | 10:19 PM
v2rider's Avatar
I have a 650V2, which is probably different, but i installed my contactor under my seat, and mine is able to work at all times. Its easier to hook it direct to the battery. It wont drain your battery unless you use it alot without the machine running.
Old Jun 30, 2006 | 04:45 PM
mybrute's Avatar
Thanks V2rider, on the brute force I ended up splicing the wire at the back of the Brute where you have a extra plug , so I didnt have to cut into my switch wires. I also mounted my contactor uder my seat where the tools go. I do have one question though, On your winch I only had a place for 2 bolt to mount it to the plate, Is yours the same way? I wonder is that enough bolts?
Old Jun 30, 2006 | 04:55 PM
v2rider's Avatar
Two bolts . Let me take a look quick
Old Jun 30, 2006 | 04:57 PM
v2rider's Avatar
Yes two bolts is right. I have tugged on my silverado with it, so i know its plenty!
Old Jun 30, 2006 | 05:06 PM
mybrute's Avatar
Thanks for your help! I just didnt know if that was enough but I guess it is. The venom was east to install, I hope it holds up.
Old Jun 30, 2006 | 05:37 PM
v2rider's Avatar
I havnt had any problems with mine. And the only reccomendation from others is to buy your own good quality grease, take it apart, and grease it. I havnt done it yet, but a couple have had the grease in their winch dry up . Im sure i will do it sometime, but for now its working great! Good luck, and have a good fourth![img]i/expressions/face-icon-small-wink.gif[/img]
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
COFatboy
May 2, 2020 12:06 AM
Schneider
Jul 24, 2015 05:05 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
