choke question?
Old Jul 2, 2006 | 09:19 PM
daviddsims's Avatar
Default choke question?
I have a 92 fourtrax 300 2 wheel drive. I need a new starter valve for the choke on the carb but it is 45 dollars. If I just plugged the hole off on the carb would it work right or does it need the needle in there? Because I dont need the choke in the middle of the summertime in LA.
Old Jul 2, 2006 | 10:53 PM
Malkuth's Avatar
I don't know the answer to your question, but I think I would rather pay 45 Bucks on an easy fix, then spend even more on something else later on caused by your little Jimmy job. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 2, 2006 | 11:03 PM
hondabuster's Avatar
Youd have to be careful what you plugged it with. You dont want to plug any passages, with debrie from the fix. Its got be gasoline resistant, and not crumble or fall apart. What needs to be plugged, is way down inside that hole, and not just sealing off the top.
Its posible to use the black rtv, which is oil and gas resistant, and it should come out in one plug when youre ready to fix it proper. Dont go over board, just use enough to do the job.
Old Jul 3, 2006 | 12:14 AM
daviddsims's Avatar
So when the needle is down in the hole would that be choke on? I just didnt know how the choke worked in the carb. I am curious about the starter valve and when u pull the cable to choke does the needle come up or does it go down in the carb?
Old Jul 3, 2006 | 12:31 AM
The plunger is lifted up, and the starter jet port is exposed, when the "choke", is pulled on. This allows the gas to flow thru the starter jet, and up into the airstream.
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
WesTech
11
Aug 11, 2015 07:55 AM
ghost civic
Jul 27, 2015 03:15 AM
