Polaris Sportsman 335 Cutting Out
Old Jul 10, 2006 | 04:53 PM
agman's Avatar
Default Polaris Sportsman 335 Cutting Out
I have a 1999 Polaris Sportsman 335 that runs fine until I push it full throttle, then it cuts out. Up to 3/4 throttle it is fine. Any ideas what the problem might be?
Thanks
Old Jul 10, 2006 | 05:37 PM
duffus's Avatar
Does it do this only in gear or does it in neutral also?
My first impression was the electronic throttle control stop is being activated---
secondary-- carb issues.
Old Jul 10, 2006 | 08:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like its straving it for fuel on tyop end maybe because the main jet is getting plugged or the float level is too low.
Old Jul 11, 2006 | 10:58 AM
agman's Avatar
It only does it when it is in gear.
Old Jul 11, 2006 | 11:05 AM
scootergptx's Avatar
Supersock
Hired Gun!
If it's fine up to 3/4 throttle, check your main jet.
Old Jul 12, 2006 | 11:25 PM
ncriderforks's Avatar
There was a tsb on those models. If it has not been done, cut about 3/4 inch off the end of the snorkal and change the angle a little. Sounds like the snorkal is getting pushed up against the gas tank while you are sitting on it and its starving for air. it already is very close and when you open the throttle, it sucks the intake snorkal up against the gas tank and restricts air flow. When you let off it has enough air. If this has been done already, disreguard this. Don't just take the lid off and try it and try it, it won't run right without the lid on either.
Old Jul 14, 2006 | 12:13 AM
duffus's Avatar
is the vent tube blowing any oil into the air box?
Old Apr 15, 2021 | 05:31 PM
Steveh342's Avatar
hey, I am experiencing this issue. My 1999 polaris sportsman 335 started losing power and stalling out when I would be full throttle or pushing snow. Took the seat off and noticed the air box was broken and the hose was disconnected. The box had oil in it. Replaced the air box, lid, filter breather and spark plug. Now it idles fine and seems ok at 3/4 throttle but then it cuts out. Any ideas?
flip1014
Oct 26, 2018 08:53 PM
spark1051
Jan 18, 2015 08:53 PM
coolbreeze69
Sep 5, 2010 09:15 AM
Mud1983
Mar 20, 2009 03:00 AM
mikystyle
Jul 28, 2007 10:11 PM
