starting cold rubicon?
Old Nov 27, 2000 | 08:08 PM
cokeisit's Avatar
How do you start the ruby when cold. Having a hard time flooding and its only 20F.
Old Nov 28, 2000 | 06:58 AM
gassygordo's Avatar
Maybe your choke is sticking. Mine does, so until I get a chance to get it back to the dealer, I've been using the primer.
Old Nov 28, 2000 | 08:55 AM
hiofcer's Avatar
Mine has yet to flood but, it does seem to run really rich. It's popping through the exhaust as I let off the gas after hard acceleration. I don't see any black smoke at all either which I think is strange.
The coldest morning in which I started mine was 15 degrees. I didn't use the primer, just the choke.
Old Nov 28, 2000 | 09:51 AM
TEXMud's Avatar
The Rubicons run rich from the factory. When I installed my snorkel, it leaned it up and now it runs better.
Old Nov 28, 2000 | 04:19 PM
PimpedBanshee69's Avatar
wheres the primer on the rubicon i only saw the choke pull thing.
Old Nov 28, 2000 | 05:38 PM
TEXMud's Avatar
I believe its on the right hand side. Take off that small cover for the pull start, and it should be right there on the carb if I am not mistaken.
Old Nov 28, 2000 | 08:01 PM
BigRed450's Avatar
i believe the Rubicon has the same carb heater and primer button as the 450.
First turn the key on, pull the choke button out, wait a couple of seconds for the carb heater to warm the carb, then start. If this does not work your choke cable may need adjusting. My 450 has started in -40 degree temp using this procedure, without even using the primer.
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
neilbedwell
May 31, 2015 11:11 AM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
