trx250r engine kits well over 50HP?
Old Nov 27, 2000 | 10:17 PM
ScoobyDFW's Avatar
Who sells trx250r engine kits that will produce well over 50HP?
Am I better off starting with a cr500 motor? Who sells motor kits for the cr500 motor and could hook me up with what I need to run the motor in a quad?
Old Nov 27, 2000 | 10:57 PM
87_250R's Avatar
PSI has some kits the 425 is well over 50hp as for a cr 500 you would want to get a aftermarket frame built for the engine a stock frame would probaly break a lot and have tons of viberation. for more info on the PSI's web site is http://www.psiperformance.com/catalo...6_Honda250.htm and for info on a PRO-TRAX CR500R go to http://www.yamahayz26.allmypages.com/ and click on PRO-TRAX on the left. what do you want to build your "super quad" for?
Old Nov 27, 2000 | 11:05 PM
87_250R's Avatar
how do you know "22" or 23" dirt tires for the front to reduce caster for better handling" does it cange some way?
Old Nov 30, 2000 | 12:13 PM
Kybol's Avatar
The PSI 265 kit is supposed to make around 65 HP.
slowgsxr97
Mar 18, 2022 03:40 AM
ghost civic
Jul 27, 2015 03:15 AM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
toonces
Jul 11, 2015 12:01 PM
