air filter
Old Jul 19, 2006 | 11:19 PM
chrisrichc's Avatar
Default air filter
will a after marker air filter help performance on my 05 rancher? if so. which manufacturer do you recommend. KN a good brand. and what kind of benifits to doing this. thanks for any and all replies.
Old Jul 19, 2006 | 11:31 PM
YFZracer12's Avatar
Default air filter
UNI is allright on a utillity
Old Jul 19, 2006 | 11:53 PM
dunefool's Avatar
Default air filter
Don't waste your money.
Old Jul 20, 2006 | 12:23 AM
MikeMac707's Avatar
Default air filter
it wont help ur performance in a great deal for what u would pay for a new air filter....the best thing a new filter would do is make the quad sound cooler...
Old Jul 22, 2006 | 09:05 PM
quicksilver's Avatar
Default air filter
I put a UNI on my 2005, no difference.
If you want power gains, you need to start with a pipe/jetting/air filter combo. The 350's are corked up pretty good from the factory. A pipe and jet kit get's the engine to breathe a little better, I've heard noticable differences can be expected if set up properly.
Old Jul 23, 2006 | 12:29 AM
Rinman's Avatar
Default air filter
An aftermarket air filter will help a little. But you won't feel the power. One thing you can do to that Rancher is clip the carb spring. This is FREE and makes a very noticeable difference. All you do is remove the 4 screws from the top of the carb. Becareful they strip easily. Remove slowly and remove the spring. Count off 11-12 coils counting the bunched up ends as one and cut. Reinstall the longer piece and the cap and 4 screws. This really only takes a couple of minutes and is FREE and works. This doesn't give you anymore power but will really improve throttle response. You will probably be able to wheelie after this simple mod. It will not hurt anything at all. Everybody who does this can't believe the difference.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
