rancher fan
Old Jul 20, 2006 | 06:52 PM
mastinson's Avatar
Default rancher fan
I just ordered a fan for my 06 rancher and have some questions.
Where is the best wire to tap into where my fan will run when the engine is on?
Does the fan need to be pointed towards the oil cooler or towards the engine?
Will running the fan all the time cause the fan to overheat and die?
Old Jul 20, 2006 | 07:30 PM
mykool61679's Avatar
Default rancher fan
you would be fine with out one. they dont even put them on the manual 2wds.
Old Jul 20, 2006 | 08:18 PM
MikeMac707's Avatar
Default rancher fan
not sure about the best wire... but mine is pointed towards the engine and its not smart to run the fan all the time...wastes energy
Old Jul 20, 2006 | 09:21 PM
mastinson's Avatar
Default rancher fan
When I say direct when the engine is on what I really meant is wth the use of a toggle switch, but I will probably leave it on during the hot months so it will be on soon as I turn the key. Also acourding to the service manual the fan should be pointed towards the oil cooler which would mean the motor on the fan should be facing the motor of the atv.
Old Jul 20, 2006 | 10:20 PM
Default rancher fan
mine has a fan and its only kicked on maybe 5 or 6 times in the last 40 times ive rode.with the exception of being cooled off in a water hole or three, you really dont need the fan. why did you buy one?did you have one already and it broke? but if that was the case you would already know were to run the wires.
Old Jul 20, 2006 | 10:26 PM
MikeMac707's Avatar
Default rancher fan
thats a waste of battery power and fuel...it takes me miles of riding in the heat for the fan to kick on
they didnt add one to the new models for a reason... it doesnt really even do much
Old Jul 21, 2006 | 12:05 AM
4wheelerfred's Avatar
Default rancher fan
me and mike drove 25 miles in 90 degre weather and it kicked on once for 5 min.
its not even worth having.
Fred
Old Jul 21, 2006 | 12:49 AM
quicksilver's Avatar
Default rancher fan
if i'm not mistaken, isnt the wire plug-in already there for the fan, even on the 2wd's??? As far as i know, the thermo-switch that turns the hot light on also turns the fan on.
the plug-in should be toward the front somewhere, way up above the front wheels, up under the main front plastic piece. Look around for that.
the fan should blow the air towards the motor when it runs, mounted to the rear of the oil cooler.
I'll look at my Honda manual wiring diagrams, it has all the wiring diagrams for all the ranchers, 2wd, 4wd, canada models, USA models, etc. I'll get back to you...
Old Jul 21, 2006 | 10:59 AM
Default rancher fan
i looked in my 2004 Rancher service manual, and The wiring is all there for the fan. The fan assembly itself actually has some wiring to it, it's a few feet long, it plugs into 2 connectors that are tie-strapped to the frame, near the right inner fender area. the wire colors on the vehicle is a blue and white wire for an '04, might be different for '06. When the fan runs, it should blow air towards the engine.
Old Jul 21, 2006 | 05:42 PM
mastinson's Avatar
Default rancher fan
But try spraying fence row for an hour in 2nd gear and see if you think that fan is a waste lol.
