blaster problem!!! need help
Old Jul 24, 2006 | 10:39 PM
bfastorblast's Avatar
Default blaster problem!!! need help
hey guys i have an 05 blaster with a toomey pipe on it and i have a problem every time i go into 6th gear just cruising the engine just quits and the when i start it again it dosent want to idle then when you get going again it will idle atfer just like nothing ever happend. that happend three times now and now atfer the 3rd time i cant even start it.
and just befor this whole thing happend i washed my quad and i sprayed the the carb with the pressure washer pretty hard so im thinking i might have water in my carb and i change the plug but nothing happend so any suggestions. thx
Old Jul 24, 2006 | 10:43 PM
JLsparky7's Avatar
turn your gas off and stand the quad on the grabbar to drain the carbs. Then set it back down and turn the gas back on. If that doesnt work then take the carb apart and clean it. Its not hard.
Old Jul 24, 2006 | 11:28 PM
i just figured out that i have no spark so could it be the ignition coil?
Old Jul 25, 2006 | 05:56 AM
JLsparky7's Avatar
Put in a new plug and make sure its gapped correctly. Its probably not the coil, its brand new almost. Try spraying some carb cleaner in it and starting it.
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
