Stumped with the raptor???
Old Jul 25, 2006 | 04:42 PM
Raptor0502's Avatar
Default Stumped with the raptor???
ok so i go out and start the raptor(660) and it idles ok, but after about a minute or so it cuts out hard and it also cuts out whenever you give it a little throttle. so i clean and blow out the carbs and it runs fine. about a weak later i go to take it out and its doing the same thing, im sick of ripping the quad appart to get to the carbs. when i give it throttle it spudders and dies and sometimes backfires violently. if the carb is clogged then which parts of the carb should i focus on cleaning. i have a feeling that the floats might be stuck or something???but idk. any help would be good.
Old Jul 25, 2006 | 06:52 PM
Raptorracer2051's Avatar
The same thing just happened with my 02 Raptor, it would idle fine but when u gave it throttle, it would pop and backfire. It turned out it was the parking brake rev limiter. Just make sure your parking brake cable is tight. We thought it was the carbs too but it was just that rev limiter.
Old Jul 25, 2006 | 06:55 PM
Oh and i was also thinking of putting an hmf pipe on my raptor. Did it help your quad a lot? and is there a big difference between the slip on and the full system?
Old Jul 25, 2006 | 08:04 PM
Raptor0502's Avatar
yea, the cable is tight. but yea the hmf is a great pipe, i went with the full system and it makes a huge difference, its like a whole new quad. i would say if you haev the money then get the full system, if not go with the slip on. stock i was probly puttin out around 37, 38 hp. with the hmf im probly in the mid to high fourtys, but thats with an air filter and adaptor plate which is also a good investment.
Old Jul 25, 2006 | 08:08 PM
Raptor0502's Avatar
oh yea, and i would say that there is a good difference in the hp levels that the full system and the slip on system put out. the stock raptor headers are really made for a quad that is around 400cc and they are way to restrictive.
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
