400 ex motor oil
Old Jul 27, 2006 | 01:38 PM
Honda400exster's Avatar
Default 400 ex motor oil
i just put a K&N airfilter in my 400 ex and it startes smoking a lot a few days later soo i checked the oil and it was empty soo i filled it with 10w40 which is what i heard was good for it but it still smokes any ideas why its smoking...
Old Jul 27, 2006 | 01:45 PM
BlackandRedWarrior's Avatar
Air Cooled Rider
Future Govenator of Kalifornia!
This is gonna hurt....
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Jul 27, 2006 | 01:49 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
You could have ruined your rings and or scored your cylinder wall. Is the oil made to run in your ATV? If it's for your ATV then you have problems, if not drain it, drain the filter and add oil made for your ATV. If it's still smoking refer to the first part of this reply. =[
Old Jul 27, 2006 | 01:55 PM
it opnly smokes gray-ish smoke when its warming up after its warmed up its fine..and if u know of the exact motor oil said to be used from the owners manual let me know...i just ordered one [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 27, 2006 | 02:01 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
Veteran: Army
Loved
Community Favorite
Well I hope it's OK, If you feel it's ok when you change the oil change the filter also. I didn't mention changing it earlier cause if it was f,uped there was no sence in changing it to see.
You should be able to go to honda's website and get all the info you need about which oil is for your machine. You can also go to the oil manufactures website and see what the oil you used is blended for. Good Luck. =]
Old Jul 27, 2006 | 02:10 PM
i talked to a few buddies of mine who own a 400 ex and they said it shouldent be the oil and that theres did the same thing after changing the oil..it only smokes for like 1minute on a cold start and runs fine..the only thing i could think it could be would be the valve seals? mabe there leaking a little bit?..?
Old Jul 27, 2006 | 02:16 PM
bango18's Avatar
in a 400ex u cant use oil with moly......moly is short for some longer word that i cant remember haha....but because the engine and tranny share the same oil in the 400ex the engine oil cannot have moly or it will mess up your clutch....best bet it to go to the closest honda dealership and get the honda oil....i run 10 w 40....WITHOUT MOLY
Old Jul 27, 2006 | 02:25 PM
the motor oil im using is Napa premium performance SAE 10W40
Old Jul 27, 2006 | 03:44 PM
okbeast's Avatar
I'm running 20w50 KawaChem non-synthetic. I'm running the thicker oil because it's so hot where I ride that it helps it to not break down as easy. Also if it smokes a little after you changed the oil you may have added too much because technically it only needs 1.95 qts but I usually just pour the whole 2 in. My valves seals are also a bit leaky so it smokes a tad. I just make sure to check it before I ride.
Old Jul 27, 2006 | 04:38 PM
ss97's Avatar
Lets Ride!
You are running automotive oil?
