plastic revival tips?
Old Jul 17, 1999 | 10:01 PM
robandkc's Avatar
i have an old 84 suzuki 125 that needs desperate help witht the plastic. it sat out in a yard uncovered for like 5 years and has gone from orange to almost pink/white. i have found the new layer of rich orange plastic under it but need to know how to get to it the fastest way ( sandpaper gets clogged to fast, a razor is faster but tiring.) also once im there how can i sand the plastic w/ out dulling it? i have to do all the plastic and no aftermarket plastic is available. thanks alot---any experience w/ PC1 plastic renew? thanks alot
robert hammond
Old Jul 18, 1999 | 09:43 PM
EXtreme's Avatar
Try a broken piece of glass with some duct tape for a grip. This is an old timer trick for refinishing furnature. Use the edges to shave (like stopping on hockey skates)the plastic down to where you like. As far as sanding, how bout a palm sander? Good luck, looks like job for rainy day!
Steve Small, 00' 400ex, 00' 325 Trail Boss for the Mrs.
Old Jul 18, 1999 | 11:44 PM
Boger's Avatar
n/m i need to reed a little more
*400EX*Big Gun Headers and Slipon. White Bros. Rev Kit. Looking at new carbs. *LT250R*FMF Pipe and Power Core Silencer. Keihin Carb. Boyesen Reeds. Evan Johnson Email: JaVa003@AoL.CoM
[This message has been edited by boger (edited 07-18-1999).]
Old Jul 19, 1999 | 09:41 PM
jhall's Avatar
You can try wet sanding the plastic with a coarse sandpaper then you'll need to sand it again with a finer sand paper to get the ridges out. Also I've used Plastic Renew from PC racing it takes alot of work to get the plastic back in shape but the results are worth it.
Old Jul 26, 1999 | 02:23 PM
KevWarrior's Avatar
Sorry no tips on the plastic, but I also have an old 1984 Suzuki LT125, what are the chances. It was a good starter and still runs fine today.
Kevin JA Works of Georgia
1996 Yamaha Warrior
Old Aug 26, 1999 | 04:37 PM
EXtreme's Avatar
I took advise from another post under "Yahama" that said to use a Scotch-Brite pad and Mop-n-Glo floor polish. I tried it on my 400ex plastic and it's back to showroom condition.
Use the pad to buff out the scratches, wipe it clean, add the mop-n-glo, steel wool between coats, and buff to a shine! Total time was about 15 minutes and cost was $4.00
Old Aug 26, 1999 | 09:07 PM
TRXter's Avatar
Hey Steevy, What color pad did you use, red, brown, maroon?
TRXter
400EX
Old Aug 26, 1999 | 11:52 PM
EXtreme's Avatar
lets try the spiffy green color with the sponge dooby on the other side...works good for applying the mop n glo. Cancel the steel wool, makes like starting from scratch (no pun intended)
Old Aug 30, 1999 | 11:35 PM
TRXter's Avatar
Spiffy, LOL!!!
TRXter
400EX
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
