LT 50 won't start need help!!!!
Old Aug 1, 2006 | 06:08 PM
crazy90's Avatar
Default LT 50 won't start need help!!!!
1984 LT 50... It was running excellent the last time my girls road it and it started to bog out and then quit running. Since then I have installed a new carb, plug, checked compression, getting fire and still wont start. Any ideas on what I have left out????? I have run the adjustment screw on the carb in and then back out 1 1/4 turn and then tried increasing up to 2 turns and still nothing. I have tried to start it with it in the prime position and with it on pos. no luck. When I pull the plug it seems not to be wet with fuel.... I open the drain on the bottom of the carb and fuel runs out. I need some help with this one. My arm is about to fall of from pulling the rope.
Thanks in advance
John
Old Jan 23, 2008 | 08:17 PM
moomba99's Avatar
I know this thread is pretty old and I did not notice any replies. I am having the same exact problem with my 03 lt50. Did you ever figure it out. I am about to put this thing next to the trash can.
Old Jan 24, 2008 | 02:19 PM
hondabuster's Avatar
Are you getting spark? Thats the most important thing to start on. Try a new spark plug if no spark.
Then check compression, and if that looks good, the carb could be plugged. Look very closely at the pilot jet. The center hole is incredibly small, and plugs very easily. If you can't see light coming thru the pilot jet, then replace it.
If those dont help, then i think the flywheel will need to come off, and check the key, if its dented, or sheared, the timing is off, and that can do the no start.
Old Feb 8, 2008 | 09:59 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
Ah.. how long did it sit idle? Did you use Stabil when storing it? I'm betting you have a gummed up carb. Probably the float valve is stuck...
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
