warrior not running
Old Aug 2, 2006 | 07:47 PM
ridingr6's Avatar
Default warrior not running
my 2000 yamaha warrior starts and idles but when you accellerate it back fires thru the carb when going in a straight line, turn the bars it takes off and seems to run fine, go straight again and it spits and sputters again. I checked the simple things. fuel, fuel shut off, air cleaner, what should I cchech next. thanks for the help.
Old Aug 2, 2006 | 09:08 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
sounds like a pinched throttle cable...
Old Aug 3, 2006 | 04:04 PM
recon99's Avatar
check the intake manifold, it's common for them to crack down the middle and cause it to run erratically. Probably the boot is cracked, and just the movement of the throttle cable when the bars are turned is enough to push the carb side to side, opening and closing the crack.
njrider64
Jul 4, 2017 01:40 AM
tpd270
Jul 1, 2015 08:18 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
dunc_n
Aug 26, 1999 09:32 PM
