Blaster oil injection block off.......
Old Aug 3, 2006 | 05:27 PM
JLsparky7's Avatar
Default Blaster oil injection block off.......
Just wondering what you have to do to block off the oil injection on the blaster and just run it mixed?
Old Aug 4, 2006 | 12:50 AM
JLsparky7's Avatar
No one has any ideas?
Old Aug 4, 2006 | 01:42 AM
Atvstevo1337's Avatar
I just took off the whole oil pump and pipes with it and sealed the inlets
Old Aug 4, 2006 | 05:28 AM
JLsparky7's Avatar
Wheres the oil pump and what did you seal the inlets with?
Old Aug 4, 2006 | 02:38 PM
JLsparky7's Avatar
Anyone?
Old Aug 5, 2006 | 12:53 AM
JLsparky7's Avatar
anyone?
Old Aug 5, 2006 | 05:13 PM
Boomer2's Avatar
The pump is on the clutch side of the engine, the side where the kick start is. At the front of the engine there is a plastic cover with 4 or 5 screws, that is seperate from the clucth cover. Take the pump off and remove the plastic gear and put the pump back in. make sure you put the gasket back on the pump. On the carburator use an epoxy or JB weld to seal the oil inlet. Its better to get a kit, but if you can't afford one this will do, just make sure you seal up the oil inlet on the carb good because it will lean out your jetting. If you check out the links on my webpage there are alot of links to blaster specific sites, that have information on how to block off injection.
Old Aug 5, 2006 | 08:02 PM
JLsparky7's Avatar
Thanks a lot for the help, ill check it out.
ReconBayou
Oct 31, 2022 05:37 PM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
