Need help w/ 150 atv!
Old Aug 9, 2006 | 07:58 PM
atvmike92's Avatar
Default Need help w/ 150 atv!
Ok I cleaned my air filter and oiled it and now I tried running it. W/out reving it, it was already
idling at a high rpm. Did I put too much oil on it? Thanks for any help.
Old Aug 9, 2006 | 09:51 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
If all you did was clean and oil the filter than yes you most likely have to much oil and its richened the carb a bit. Sort of like having the choke on. I squeeze out most of the oil when I oil filters.If you can squeeze the filter and get oil to come out, youve got to much oil in it . It only takes enough oil to change the filters color, or darken it if the oil is relatively clear, for the oil to work.
Old Aug 9, 2006 | 10:21 PM
atvmike92's Avatar
Thanks mwq. If I ride like this will it hurt the engine? Ill try to squeeze some oil out later.
