Electrical problem w/ Kazuma Falcon 90
Old Aug 9, 2006 | 10:33 PM
DarrenMc32's Avatar
Default Electrical problem w/ Kazuma Falcon 90
Does anyone have a wiring diagram for this bike? It's been pretty much trouble free until the other morning when we went to start it and ... nothing!! When the ignition was turned on and the starter button pressed, nothing happened. The battery is charged but that thing has more wires than I expected when I began troubleshooting. Anyone have a simiilar problem before? Any suggestions are appreciated. Thanks, Darren.
Old Aug 10, 2006 | 12:45 AM
RacewayATV's Avatar
DarrenMc32
If you want to give us a call when you are with the ATV I think we can help you out!
Old Aug 10, 2006 | 09:37 PM
Radrob99's Avatar
check the fuse all these bikes have a little auto type fuse in them that will keep it from turning over the starter there is also a little selonoid in there try to bump it like you do a car selonoid and see if it has power I'm not real familar with falcon 90 but' ther all kinda the same
Old Aug 21, 2006 | 11:20 PM
DRUEandTYLERSdad's Avatar
My problem was in the switch itself. I took it all apart and one of the wires that is soldered had come loose. I resoldered it, as well as the other, put it all back together and it worked fine after that.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
