banshee kick starter gear prob.
hi just yesterday my case was making a noise i took it apart and seen the gear that rotates in and out as you kick the kicker the gear is a littil gear with a metal ring that has a eye bent in it that gos into the hole in the case when started but when i took it apart the metal ring was way at bottom the eye part it was holdind the gear out a littil causing it to rub the idel gear i been puting it back in but it wont go ack to nuertal postion the eye wont fall into the hole alwas off by a hair plus the metal ring i can trun it around n around is that normal or is it soppse to be solid
Jul 7, 2015 11:00 PM
