Raptor valve adjustment "HELP"
Old Aug 14, 2006 | 04:52 PM
BassBlaster's Avatar
Default Raptor valve adjustment "HELP"
I am adjusting the valves in my raptor 660. I adjusted the intakes and the the exhausts and put everything back together fired it up and valves tapping loudly. I took everything back apart and intakes were real loose so I readjusted the intakes and the exhausts got real loose. What am I doing wrong? Is there a certain order these should be adjusted in? Am I using the right TDC mark? There were two marks one is an "H" type mark and just past that one is a line. I used the "H" type mark. Please help fast....thanks
Old Aug 14, 2006 | 04:55 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
how far were they out of adjustment?
sounds like you didnt have tdc
raptortranny.com has a tutorial with pics
Old Aug 14, 2006 | 05:07 PM
I went to raptortranny.com and read there piece and I do believe I was not at TDC. Going back out to try it again right now. Thanks for your reply.
Old Aug 14, 2006 | 06:02 PM
Went back out and did it again. Turns out I was using the right timing mark, just was not at the beginning of the compression stroke. She's runnin now. Thanks alot!
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 22, 2015 06:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
