Starting Problem, help
Old Aug 15, 2006 | 04:23 PM
dabrowat's Avatar
Default Starting Problem, help
I have a 2003 trx400ex (electric start). When I try to start it, all i hear is the starter. Sometimes i can hear the engine trying to turn on, but it doesn't. Is this problem caused by a weak battery? When i push the atv from 2nd gear, it starts and everything is fine. Thanks for the help.
Old Aug 15, 2006 | 06:04 PM
hondabuster's Avatar
When you say all you hear is the starter...does it mean its spinning...or just clicking?
If it is just clicking and doesnt spin, clean up the battery terminals, and cable ends. If that doesnt help, get the battery load tested.
Old Aug 15, 2006 | 06:15 PM
dabrowat's Avatar
Most of the time it clicks. Other times I hear the engine trying to start.
Old Aug 15, 2006 | 06:54 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You have a low battery. Try charging it with a trickle charger and as mentioned, clean the connections.
I have at times jumped my sons 400ex with a jumper box.
Old Aug 15, 2006 | 08:18 PM
dabrowat's Avatar
Can I jump start it by connecting to a car?
Old Aug 15, 2006 | 08:39 PM
Yep, just make sure the donor car is NOT running, and its ok. If the car is running, the alternator can put out 15 or more volts, which will trash the quads electrics. If the motor is off, all thats put out is 12.7
Old Aug 15, 2006 | 09:28 PM
dabrowat's Avatar
So all I do on the car is turn the key once, as if I just wanted to listen to the radio?
Old Aug 15, 2006 | 10:16 PM
Joshwfl's Avatar
Don't even put the key in the ignition!
Old Aug 15, 2006 | 10:35 PM
Well put. I should remember to say that.
Just use the jumper cables, and no key at all in the car. Dont worry about running the car battery down...it has much more capasity than a quad battery.
Old Aug 16, 2006 | 12:14 AM
dabrowat's Avatar
So i should connect the batteries and then what? I don't even put the keys into the car ignition? How long should i keep them connected? Should i start the atv while the batteries are connected? Thanks
