Blaster t.o.r.s removal question
Old Aug 19, 2006 | 04:58 PM
01spanky's Avatar
Default Blaster t.o.r.s removal question
well i just got the vitos kit to remove the tors. i hooked it all up and did the idle screw but ill fire the bike up and itll run but i cant get it to stay idling?if i let go of the throttle itll die. so how do you get the idle to stay? and do you take off any wires besides the one that plugged into the tors
Old Aug 19, 2006 | 05:55 PM
JLsparky7's Avatar
I just went through this.
1.Cut the wire on the bottom of the silver part above the carb
2.I also cut the wire that goes to the box above the thumb throttle (mine was dying unless i held the throttle too, until i cut this wire)
Old Aug 19, 2006 | 08:03 PM
01spanky's Avatar
the wire that looks like a ground conneted to the ignittion coil?
Old Aug 19, 2006 | 10:01 PM
JLsparky7's Avatar
the wire about 2-3 inches right below your idle adjustment. and the wire ( not the cable) that comes out of your throttle box (right above your thumb throttle). As well as the box which you have already done. I didnt even need the TORS removal kit, mine runs beautifully now. My friend eric didnt need the kit either.
Old Aug 20, 2006 | 02:08 AM
01spanky's Avatar
i cut the wires by the thumb throttle and it wouldnt start at all. the wires go inside that box and hook up to another little box with a button on it, what is that?
Old Aug 20, 2006 | 04:45 AM
JLsparky7's Avatar
That is the switch that controls the idle with the tors, also controls your parking brake rev limiter. Try turning your idle all the way out and go up 1/4 turn at a time till it runs.
Old Aug 20, 2006 | 12:39 PM
fastquad02blaster's Avatar
I understand that one wire to cut is down on the carb. Is the other one up by the handlebars right by the actual thumb throttle lever? I really don't want to mess anything up. Does unhooking the tors give you any more power or just eliminate the rev limiter? Is all you have to do is clip the wires you were talking about or do you have to buy a kit?
Old Aug 20, 2006 | 02:55 PM
JLsparky7's Avatar
I just clipped the wires on me shee and it runs beautiful now. As for cutting the wire above the thumb trottle try taking apart that box and pull the switch out and see if itll run without it. Mine wouldnt run with the switch.
Old Aug 26, 2006 | 11:19 AM
What would control your idle speed after you bypass all the tors stuff? From what I'm understanding, the idle speed adjustment is on the tors deal on top of the carb. Is it part of the tors also? Would you have to buy the new carb top to be able to adjust your idle speed?
Old Aug 26, 2006 | 02:40 PM
JLsparky7's Avatar
I can adjust my idle just fine and all i did was cut wires, i didnt buy the kit.
