Cams question
Old Aug 20, 2006 | 06:54 PM
DragonDJ11's Avatar
Default Cams question
When you send in Cams for a core charge, what exactly do you do? Do you remove the sprockets from them? What about the decompression lever? I have heard you do not put the decompression lever back on the new ones is that true? I am trying to scrounge enough for some cams before DS Days, any help available please????
Old Aug 20, 2006 | 07:06 PM
2BIG2BFAST's Avatar
sent my cams in with the sprockets and everything and they mounted the sprokets on the new cams for me.
Old Aug 20, 2006 | 09:49 PM
ERBEDS650's Avatar
Web will take them off, but wont put them back on.
Old Aug 20, 2006 | 10:55 PM
OregonDunePatrol's Avatar
RWR will take the sprocket but not the compression release. If you dont remove it, you wont get one with it back!
Old Aug 24, 2006 | 12:20 AM
DragonDJ11's Avatar
What is the best way to get the decompression lever off? Also, is it needed??????
Old Aug 24, 2006 | 10:31 AM
650VIPER's Avatar
It makes it easier to turn over, by releasing cylinder pressure at low rpms. It not a necessity.
I take a towel, and wrap it around the cam until there is no towel left hanging, then put it in the vice, and take a punch and punch it out. You need to be very careful not to damage the cams, so wrap that towl tight, and use enough to protect it. Its a bugger the first time.
Old Mar 16, 2007 | 03:04 PM
HeadsupRacing's Avatar
Very good info.
bigred20653
Oct 2, 2015 10:05 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Brandon400
Sep 5, 2015 08:44 PM
