Cams question
When you send in Cams for a core charge, what exactly do you do? Do you remove the sprockets from them? What about the decompression lever? I have heard you do not put the decompression lever back on the new ones is that true? I am trying to scrounge enough for some cams before DS Days, any help available please????
It makes it easier to turn over, by releasing cylinder pressure at low rpms. It not a necessity.
I take a towel, and wrap it around the cam until there is no towel left hanging, then put it in the vice, and take a punch and punch it out. You need to be very careful not to damage the cams, so wrap that towl tight, and use enough to protect it. Its a bugger the first time.
