need help quick
Old Aug 20, 2006 | 08:30 PM
05dsrider's Avatar
Default need help quick
i was riding earlier and all the sudden it sputtered out of the hole and so i let of n went to hit it again n nothing it sputtered like crazy so i took it to the shop and pulled the top end of the carb off n made sure everything was ok then drained the bowl thinking it had water in it and now it starts up runs great except at very top end it sputters like crazy and i tried with the lights on thinking it might be electrical ... please help and thanks in advance
Old Aug 20, 2006 | 08:32 PM
05dsrider's Avatar
i forgot to add i put new plugs in it
Old Aug 20, 2006 | 08:58 PM
Howee's Avatar
Hi 05dsrider, awhile back I installed new plugs and had engine sputter under a load
but it idled fine. An engine analyzer showed one of the NEW plugs was bad. I would also check
for dirty jets and airflow. Another tricky problem I had only at fast throttle was a loose mechanicle
choke that was closing at high speeds causing engine sputter/stall. Hope this helps!
Howee
Old Aug 20, 2006 | 09:09 PM
OregonDunePatrol's Avatar
Could also be a clogged or pinched gas tank air breather line. - if so, crack the cap a bit to see if it goes away. Also could be a bad battery with low voltage. - check that with a volt meter.
Old Aug 21, 2006 | 12:15 AM
matts01ds650's Avatar
im having the same issue and it took forever to narrow it down...i bought a new cdi, voltage regulator, cleaned my carb 4 times and its finally come down to finding the tiniest hole in the diaphram on the carb.....keep looking youll find it.....its the small obvious things that will frustrate you the most........
flyin-lowe
Dec 1, 2017 03:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
cornermike
Sep 10, 2015 08:30 AM
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
