05 Rubicon steering help
Old Aug 21, 2006 | 01:54 AM
angler's Avatar
Default 05 Rubicon steering help
The steering on my 05 Rubicon is making a popping noise whenever I turn it left and go back to the right. It does this when I have jacked up to. It sounds like it is coming from the steering shaft. Could this be a bearing? Right before it started doing this I rode quite a few rough and rocky trails in Utah. Couple times I hit a rock and the wheels turned on me pretty hard. Could this have something to do with the noise? There is no play in the steering. Thanks
Old Aug 21, 2006 | 11:22 PM
Rinman's Avatar
I don't think its a bearing. A bearing would make a grinding sound. The steering shaft should also be ok unless you rolled it over? I would really be looking at the tie rod ends, both inner and outer. Put your hand on different parts of your suspension to see if you can feel it. Is your steering harder now?
Old Aug 21, 2006 | 11:28 PM
angler's Avatar
No I did not roll it over. The steering is not any harder. I will try to find again tomorrow. Thanks
Old Aug 22, 2006 | 12:10 AM
nohorses's Avatar
I would check the bearing at the bottom of the steering shaft. I had a recon that it went out on and it did the same noise. Kind of a new bike for it to be shot on, but wont hurt to look.
Old Aug 22, 2006 | 12:00 PM
angler's Avatar
The bike does have over 3000 miles on it. How long do bearings usually last?
Old Aug 22, 2006 | 07:14 PM
MikeM's Avatar
double check these numbers, but I believe there was a recall on this
Hazard: The steering rods can separate, causing the driver to lose steering control. This could cause the ATV to crash and pose a risk of serious injury or death.
2005 - TRX500FA Foreman Rubicon, VIN 1HFTE260*54400010 to 1HFTE260*54402169
2005 - TRX500FGA Foreman Rubicon GPS, VIN 1HFTE264*54400012 to 1HFTE264*54400555
I wouldn't ride it until it was fixed
Old Aug 22, 2006 | 08:50 PM
angler's Avatar
Is there a way to find out the vin number if I can't see it? There is a winch right on top of it. Will I have to take the winch off?
Old Aug 22, 2006 | 11:37 PM
Rinman's Avatar
Don't you have paperwork? It will be on it if you do.
Old Aug 27, 2006 | 08:27 PM
angler's Avatar
I found out where the noise is coming from. It is bearing right above the steering rods. I can put my hand on the bearing plate and feel it vibrate when it pops. When I turn the wheels slow it won't do it as bad as when I turn it faster. Does anybody know what would cause this? Could there be a little rock in there?
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
