Raptor Oil Cooler Question
Old Aug 22, 2006 | 09:40 PM
velocyraptor's Avatar
Default Raptor Oil Cooler Question
does anyone have pictures of that oil cooler kit for the raptor they sell on ebay for $65? ive been wanting to buy one but i want to see how it looks first.
does it work? and was it easy to install?
heres the link
Old Aug 23, 2006 | 02:37 AM
no one?
Old Aug 23, 2006 | 03:36 PM
MONSTERMATT's Avatar
DUDE I THOUGHT IT WAS WAY MORE THAN 65$
Old Aug 23, 2006 | 04:13 PM
there are other that are more expensive
Old Aug 23, 2006 | 09:38 PM
Doctorturbo's Avatar
GOT BOOST!
My first thought is why do you want to put one on?
If you ask me it's just something to pop a hole in and loose your engine.
Old Aug 25, 2006 | 01:30 AM
IT is actually not a "cooler" per say but it is a "larger capacity" oil resoivior which allows you to run approx 2 more quarts of oil which in turn causes the oil to be less "hot" and the tank in questiuon is made from solid thick steel so in actuallity it will be stronger than stock, much stronger
Old Aug 27, 2006 | 04:58 PM
raptor010's Avatar
Check this out. If you want to drop your temp alittle try this super cooler plus Engine Ice coolant.
Super Cooler Link
Old Aug 27, 2006 | 05:20 PM
i already have one but its the small one, ive been wanting to buy two 20 fin super coolers, i'll think about the oil cooler a little bit more
Old Aug 28, 2006 | 12:36 AM
SO, where do u get the 20 fin coolers? it is ok to use 2 of these in the same line if you so choose? either the small or large ones
Old Aug 28, 2006 | 01:07 AM
those 20 fins coolers are sold in ebay, im not planning on using both on the same hose, im using one for the bottom one and the other for the upper hose, theres a picture of both 20 fin coolers on the auction on ebay
Firefighter400
Oct 8, 2022 06:38 PM
STLyamwar
Jul 25, 2020 04:44 AM
Aug 21, 2015 01:23 PM
metal249
Jul 24, 2015 01:00 PM
yambam13
Jul 4, 2015 01:49 PM
