Jetmoto 200 Test Ride Results
Old Aug 23, 2006 | 11:15 PM
SherpaT350's Avatar
Default Jetmoto 200 Test Ride Results
Here is what I found out after my test ride of the Jetmoto 200 :
Positives:
Has plenty of take off power
Sounds good with the stock pipe setup.
Will bring the front end up in 1 st,2nd and third going up an incline if you really pull up on it. ( remember this is break in so I am not really hard on it).
Negatives:
Headlights point to the ground about 5 feet in front of you.
All gears are too low, need a 5 speed or smaller countershaft sprocket.
This is all I can think of at the moment, all in all this is a fun machine .
Thanks,
D.
BTW: Has anyone noticed the gear ratio , has anyone looked into a bigger counter sprocket ? All the gears are too low for my taste . How about a countershaft sprocket off of a Honda XR200 , would this work ? I think 1 tooth bigger would make a heck of a difference.
Old Aug 23, 2006 | 11:28 PM
Scooter86's Avatar
Knows Old ATV Questions!
Pull the current sprocket and run down to the local dealership and see if they can match it up. Even the stealerships only charge $15.00 for a countershaft sprocket. They should at least be able to point you in the right direction if they don't have the size you need.
Old Aug 24, 2006 | 12:56 AM
Radrob99's Avatar
you can try sprocket specialists to they are pretty good about matching them up and the prices are fair
Old Aug 24, 2006 | 10:10 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I have always thought a 5th gear would be nice but also wondered if it would allow you to out ride the suspension. I will ask Eugene about different sprockets today too.
Old Aug 27, 2006 | 02:55 PM
SherpaT350's Avatar
I was reading over my posting . I actually need a LARGER countershaft sprocket not a smaller one. MyWife, what did you find out about the sprockets . I have an idea if you want to check on something for me . Can you check on the spline size on the countershaft sprocket on your XR200 ? Unless, it has a 520 chain then the sprocket pitch is too big.
What did Jetmoto say about the sprockets when you talked to them on Friday ?
Thanks,
D.
Old Aug 28, 2006 | 11:30 AM
KTM Patrol
Former Chinese POW!
There are no sprockets available from Jetmoto exceptfor stock replacement items. Eugene suggested Sprocket Specialists too. I know the XR200 uses a 520 chain but was just thinking my XR75 uses a 428. I might try Scooters idea. It would be nice to compare it to a whole bunch of sprockets.
Frisky2050
Apr 9, 2020 11:19 AM
mvwhite
CAN-AM (BRP) Ask an Expert!
Feb 26, 2020 08:54 AM
Smokinthebear
May 7, 2000 08:01 PM
sqooze
Mar 16, 2000 12:59 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
