Warrior a-arm interchange
Old Aug 24, 2006 | 09:13 PM
88yamadog's Avatar
Default Warrior a-arm interchange
I was wondering if anyone knows if a-arms from a '01 Warrior will fit my '88.I can't find any part numbers on the web to compare,and I don't want to buy these if they won't fit.I just need to know if there is a difference,is it the ball joint,the bushings,or if they won't work at all.
Thanks
Old Aug 24, 2006 | 09:47 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i do beleive they will... however... if u want.. i could measure up my a arms and give you some dimensions to see if they will...
Old Aug 24, 2006 | 10:45 PM
recon99's Avatar
Unfortunately they won't fit, the 87 and 88's have a completely different frame from the 89-2004s. So pretty much if the a-arms aren't for an 87 or 88 they won't fit. And even the 87 and 88 a-arms aren't exactly the same. 87's had replaceable ball joints, and the 88's were welded in.
Old Aug 24, 2006 | 11:19 PM
88yamadog's Avatar
Thanks for the info.Now,where does that leave me?The lower left a-arm has a bad ball joint.It's not broke yet,but I don't trust it.A new arm from my dealer is $231.Online dealers are not alot cheaper.Is there a budget alternative?
I fabricate alot for my drag car and I'm not afraid to cut and weld,but I'm hoping for an easier alternative.
Any ideas?
Old Aug 24, 2006 | 11:26 PM
recon99's Avatar
They're being parted out all the time one ebay, you could probably buy a complete set of 4 for $100 and then have the others as extras in case your other ones start wearing out eventually. You could also call around to local shops and see if they have any laying around, but that's going to be hit-and-miss.
Old Aug 25, 2006 | 07:32 PM
88yamadog's Avatar
Thanks for your advice.I'll let you know what I find out there.
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
XxS0ccerstarxX
Aug 31, 2015 04:47 AM
