05 yfz not as quick as it should be
Old Aug 27, 2006 | 06:52 PM
Jordanw's Avatar
Default 05 yfz not as quick as it should be
I just recently got a secondhand 05 yfz 450 it looks like new however I raced another 05 yfz (both stock) and he killed me, I also raced my buddies predator, I stay equal with him until 5th and then he blows by. What do I do to get my yfz back to how it should be?
Old Aug 27, 2006 | 06:54 PM
JLsparky7's Avatar
Check the compression.
Clean the air filter.
Use good gas.
Use good oil.
are your tires bald?
Are all bikes complete stock? (sprockets and all)
Are you just as good of a rider as the other guys?
Do you weigh more than the other riders?
There are alot of factors to speed, we need more details.
Old Aug 27, 2006 | 07:02 PM
bberck's Avatar
Take off and shift points are everything in a short drag especially on close quads. I wasnt very fast at all my first time dragging my 700 but after some reading on how they react and some practice, I do much better now. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 27, 2006 | 07:17 PM
Jordanw's Avatar
i am as good of a rider as the other guys, i tryed my friends yfz and there is a noticable power difference, i use 91 octane gass and am going to put good oil in it, just cleaned the air filter. i am almost shure that everythings stock, is it possable that my engin needs to be rebuilt or somthing?
Old Aug 27, 2006 | 11:41 PM
bansheeyfz's Avatar
get better with the bike and learn how to launch it properly
Old Aug 27, 2006 | 11:47 PM
Jordanw's Avatar
just to clear this up i know im not the best drag racer and i could probobly do a lot of things to improve my racing but my yfz dose not have as much power as my buddies. i am shure of this because i have ridden his and it is a lot quicker. i was wondering if there is any odvious mecanical things that would cause this.
Old Aug 27, 2006 | 11:52 PM
Atvstevo1337's Avatar
Use good gas.
Use good oil.
you forgot to ask if tires were the same size! if your running 22s and he's running 24s or vice versa theres gonna be a difference. And check how many teeth both yours and his sprokets have cause if he's changed the sprokets from wear and tear he most likely got a smaller one. thats the first thing I did was to buy smaller sprokets.
Old Aug 28, 2006 | 10:15 PM
Six2notScaredofU's Avatar
How about your Jetting? and do a Compression check.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 28, 2006 | 10:31 PM
specopsplus's Avatar
im sure you already know this ,but,are you launching in 2nd? if not try that rev the bad boy up in second...1st is useless in a drag race or hole shot for that matter ,its so short. just my 2 cents
Old Aug 29, 2006 | 09:54 AM
Scooter86's Avatar
Knows Old ATV Questions!
Your valves may need to be adjusted as well. Also, does your buddies quad sound the same as yours? He may have removed his baffle, done the cam mod and rejetted. If so, he will definately have more power than you do, but the bike will look stock.
