Advice on cutting the plastic plz...........
Old Aug 28, 2006 | 01:24 AM
JLsparky7's Avatar
Default Advice on cutting the plastic plz...........
Decided to cut the front fenders on the shee and i was wondering what would be a good way to go about doing it and what would be the best tool? Ive heard a rotozip would work but i dont have one of those any other ideas would be greatly appreciated. Im considering cutting the backs too but i think i might wait till i get nerfs to do that.
Old Aug 28, 2006 | 01:43 AM
sjd78's Avatar
I just used a box cutter. Just make a couple of light passes with it to get your line started then on the edge of the plastic work the blade all the way through the plastics and follow the line you made.
Old Aug 28, 2006 | 02:45 AM
JLsparky7's Avatar
Thats doable, got some new blades even...
Old Aug 28, 2006 | 05:07 AM
JLsparky7's Avatar
I might go with the box cutter idea, anyone else have suggestions?
Old Aug 28, 2006 | 10:08 AM
MDS2106's Avatar
I made my lines with some electrical tape then traced the tape line with a perm. marker removed the tape and cut the line with a jig saw, then took some sand paper and smoothed out the edges. Worked like a charm
Old Aug 28, 2006 | 10:05 PM
Six2notScaredofU's Avatar
Yup jig saw here too Worked real good. look at my Pics.
Old Aug 29, 2006 | 12:58 AM
JLsparky7's Avatar
did you guys do it with the plastic on the bike or off?
Old Aug 29, 2006 | 01:03 AM
ShadyRascal's Avatar
Did ours with the plastic on the bike. We put wide masking tape over the fenders, then drew with black marker where the cuts were to be made, that way you could look at the lines and see if you liked the contour. Then like the others said, a jigsaw, fine blade, and steady hand. Smooth off with sandpaper on a block to keep it on the edges and you're home free.
Old Aug 29, 2006 | 01:46 AM
JLsparky7's Avatar
Alright, jigsaw it is. thanks alot guys. Im not sure if my dad still has his jigsaw floating around would a sawsall work or would that be too hard to guide?
Old Aug 29, 2006 | 01:59 AM
sjd78's Avatar
Like I said I went with the box cutter since it is easier to handle and it doesnt leave the edge as rough as a jigsaw blade whice means little or no sanding!
