Ported Intake
Old Aug 29, 2006 | 02:11 PM
SW2steve77's Avatar
Default Ported Intake
Does anyone know the measurements of the intake after they did the port job?? I was looking into getting the measurements and doing it my self. Thanks...
Old Aug 29, 2006 | 11:53 PM
chirochris's Avatar
please dont!
Old Aug 30, 2006 | 04:01 AM
FatHolly's Avatar
The measurement at the carb should be the same as whatever carb you are running... make sure there is no lip and that it flows smooth between carb and intake. The head side is really just cleaned up.
Old Aug 30, 2006 | 04:59 AM
SW2steve77's Avatar
oh ok......So your just making the hole the same size as the one in the head. I figured that it would be something like that, but wasn't for sure. chirochris, why not......
Old Aug 31, 2006 | 09:30 PM
chirochris's Avatar
i shouldnt say dont do it cause i really dont know you or your skill level on this
with that being said....alot of people have tried/gone this route and messed them up
some people put alot of time and energy making these things right...dyno'd and all that good stuff..
what they find...and i am not the authority on this but have been here for a while and read the many attempts
if not done perfectly you can actually reduced hp and make things worse..something with back pressure and stealing hp....they cost only 75 or 150 or so depending on which you want so why would he even attemp it..plus if you cant dyno how could you sleep wondering if you did it right!
let the pro's do it
also once you mess it up you will buying one anyway..save the headache...just my 2 cents
Old Sep 1, 2006 | 04:27 AM
SW2steve77's Avatar
Makes sense. I was going to let a budy of mine which is a machinest do it and let him look at it and see what he could do. Didn't know it was that fussy. Thanks for the input. It probly save me alot of head ache like you said!!!!
Old Sep 1, 2006 | 09:26 AM
couchonwheels's Avatar
I would say that it all depends on what you want out of it. If you are on a tight budget, and want HP, then go straight to the pros. Then you are not going to waste any money. They have done all the research, and you will know exactly what you are getting.
If you are the type that likes to tinker with stuff. You can buy a used one and play around with it. If you enjoy that stuff.
I bought a used one. I had all the tools I needed, so I played around with it. Tell you the truth I have not even installed it, so I don't know if I did good or bad. But it gave me something different to do one afternoon. Some people can **** away $40 at the casino in the name of fun, I spent it on a used intake.
Old Sep 1, 2006 | 10:42 AM
chirochris's Avatar
couch, do you have access to a dyno?
if not how could you possible know you did this right?
i am just wonderig if there is another way to test this
Old Sep 1, 2006 | 05:49 PM
maxxedouty's Avatar
you can find instructions on the net step 1 - finish. if you follow each step carefully with a light hand and to remember to just clean up the castings and match ports to gaskets you can do it, or spend 3-5$ hundred & have it done. i'm paying to have mine done because they allready have them done and its just an exchange.
Old Sep 1, 2006 | 05:55 PM
FatHolly's Avatar
$3-$5 Hundred???????????????????????? HPR charges $150 for the full race port on the intake... Ron Woods charges a couple bucks more ($177)... $3-$5 hun should get you some head porting too.
