helicoil kits
Old Aug 29, 2006 | 05:40 PM
NickDS650's Avatar
Default helicoil kits
after taking the DS down to the dealership and talking to the guys there, im down to 2 GOOD options for fixing my stripped oil drain plug hole in the engine case. 1 to get the Helicoil kit to ensure a solid fix, or 2 replace the casing which would be a mini fortune. Now the prob wit the Helicoil kit is that they can get it but its $200 since its a 18 x 1.50 size, which nobody caries of course! I do not want to half *** it and try to self tap it with chance of cracking the case, and i dont want to rip the engine out which would also cost a mini fortune, so helicoil is my way to go. Now i've found kits online but they are labeled spark plug kits, does anyone know about these kits? Im going to call the dealership to ensure proper size and fitment before i purchase anything, but i thought id ask on here to see if i could get any quick responses since dealerships close so early lol, any info would be great on the kits
Old Aug 29, 2006 | 05:42 PM
supersonictoys's Avatar
what about a slightly larger automotive drain plug and retap the hole? could even be standard and no one would know. try napa auto parts and take your old plug with you
Old Aug 29, 2006 | 05:47 PM
DSNUT's Avatar
This is a brilliant idea that will save you money. Just make sure your new drain plug isn't any longer than the OEM one[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 29, 2006 | 08:13 PM
squeege's Avatar
I'm not sure how cast metal taps...but usually give about 2-3 turns with tap and back up 1 turn then continue depending how deep you are going............my 2-cents
Old Aug 30, 2006 | 01:02 AM
NickDS650's Avatar
i looked into self tapping bolts, but the length is the problem, the DS drain plug is so short, all automotive ones r so long and will hit the screen inside the engine, i could start tapping it and then cut it down to size, but that makes me nervous, id rather have piece of mind and go wit the helicoil, thanx tho [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 30, 2006 | 12:03 PM
DStroyer's Avatar
Nick,
Your going to have to drill and tap the hole no matter what you do. The helicoil kit comes with its own tap and drill. You dont have to spend 200 bucks on this. 20 tops. Go to your local hardware store. Pick up a 11/16 drill, a 3/4-16 tap, a 3/4-16 hex head bolt and 1 oring. Ive done this on alot of stripped out drain plugs. Ace hardware carries the tools cheap, but if you need a place to buy them, try www.mcmaster.com. Just my 2 cents. Tapping the hole wont be difficult, just keep the tap straight. Take your time and you will have this done in 15 minutes.
Gary
Old Aug 30, 2006 | 12:28 PM
ThrashAndCrash's Avatar
I can't add any more opinions than the others have given, BUT when you do your work be sure and get some GOOD drill oil that is ment for aluminum. Use it for drilling and for tapping.
Old Aug 30, 2006 | 12:40 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
And a dam good suggestion none the less. [img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 30, 2006 | 03:19 PM
NickDS650's Avatar
thanx alot u guys, luckily a local shop has the 18 x 1.50 helicoil so shes gettin all fixed up right now! Thanx to all for their input!
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Alex G.
Sep 16, 2015 12:13 PM
Lou Domenech
Sep 11, 2015 06:35 PM
Jaymc
Sep 11, 2015 07:45 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
