Banshee Radiator Resevoir question?
Old Sep 1, 2006 | 12:34 AM
cmatthews24's Avatar
Default Banshee Radiator Resevoir question?
On my stock radiator overflow tank....
There's a place for a hose on the bottom, and a place for a hose on the top....
Do I hook the line that goes to the radiator, to the bottom or top?
And, Do i hook the resevior overflow hose to the bottom or top?
Thanks for your help!!!
Old Sep 1, 2006 | 12:35 AM
dirtrider38's Avatar
you hook up the bottom on to the motor
i beleive
Old Sep 1, 2006 | 12:41 AM
thats the way i have it...
but lately, my cooling system has been acting really weird...
cuz everytime, i give it just a little throttle, coolant pours out of the overflow for the resevoir....
I think i have a bad radiator cap...
because the the radiator cap is only supposed to let coolant into the resevoir when the motor is overheating, and my motor is not overheating
Old Sep 1, 2006 | 04:10 AM
kawiking's Avatar
alot of people just take the reserve bottle off.
Old Sep 1, 2006 | 03:27 PM
JLsparky7's Avatar
I was thinking of doing the same thing. Just run the hose from the top of the radiator to where ever the other hose off the reserve runs. I was gunna get a clear hose too so i can see if im running low.
Old Sep 1, 2006 | 09:58 PM
HMFIC's Avatar
The resevior catches coolant if it overheats and lets coolant into the radiator if it gets low. I didn't run an airbox on my banshee when i had it so I went to walmart, picked out a clear plastic bottle with a screw on top that looked like it would fit behind the gas tank cover on the left front side right above the left front bolt that holds the tank to the frame. I ran a clear hose from the nipple right below the cap to the bottle. I cut the hole in the top of the bottle a little smaller than the hose so that when I pushed the hose through the hole it would fit tight enought to seal itself off and then I ran the hose about 7/8ths of the way down in the bottle so that if it overheated it could push coolant into the bottle and if needed coolant it could still siphon coolant from the bottle to the radiator and I could always look through the two vents in the radiator cover to see if I had lost any coolant. If you want to get rid of all those hoses and the tank just try this out.
Old Sep 2, 2006 | 05:19 AM
JLsparky7's Avatar
Can u get some pics of that up?
cornermike
Sep 10, 2015 08:30 AM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
Logan Collins
Sep 5, 2015 08:03 PM
