dinli 90 toon carb with 28 mm koso carb
Old Sep 1, 2006 | 01:13 AM
scooter0946's Avatar
Default dinli 90 toon carb with 28 mm koso carb
i would like to find out how to toon the carb so it wont be to lean . i need help havent messed with 2 stroke befor
Old Sep 1, 2006 | 08:06 PM
Fastestdad's Avatar
Bigger mainjet. Take it out at the bottom. 11/16 plug on the float bowl and inside it is the brass mainjet 1/4" socket. On a piped bike you'll need a 142-152 mainjet I'm guessing.
Old Sep 2, 2006 | 01:39 AM
how do u know when it is too rick or lean it has a 130 and wont run on a 142 i have tryed alot of differant ones and 130 runs the best so far so how do i know witch air jet to use with it ???????? and what plug to use it is all new to me thanks
[img]i/expressions/face-icon-small-sad.gif[/img]
Old Sep 2, 2006 | 10:05 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Work from the slow, needle to main. Turn the gas off. Does it run better as the carb runs out of fuel? Yes, then you are too rich. OR cover a portion of the air filter. Does performance improve? Yes, then you are lean.
Old Sep 2, 2006 | 11:08 AM
Qwadwheeler's Avatar
Holler back at me and I'll walk you through the tune-up. I'll take you through a proper carb tune from air screw to main jet and while we're at it we'll check the clutch work. Have a complete list of what you have done as far as mods to make it easier. We'll make'er rock!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
