will a wiesco piston kit give me a lot more horse power for my 400ex?
Old Sep 1, 2006 | 04:25 PM
drag101's Avatar
Default will a wiesco piston kit give me a lot more horse power for my 400ex?
will a wiescoe piston kit give me more power for my 400ex? and does it come with rings?
Old Sep 1, 2006 | 06:21 PM
slomoe's Avatar
only if it is differant than the stock like a higher comprssion or larger piston
Old Sep 1, 2006 | 07:09 PM
2manytoys's Avatar
No it will not give more HP. You need a stroker kit for more hp. Even a cam, porting, bigger carb etc...
Old Sep 1, 2006 | 08:57 PM
TractorPacker's Avatar
Do you have a balloon?
So an oversized or higher compression piston, won't incease power???????????????
WOW!
Old Sep 2, 2006 | 11:26 AM
2manytoys's Avatar
Not very much because you did not change the stroke. You may only get about 1-2 hp gain by going to a larger size. The stroke and head work is where the most hp gains will be at.
Old Sep 2, 2006 | 05:06 PM
So a 2 hp gain(7.4%) is not enough gain for you?
I have a stroked 400ex. Is gained a ton of torque, but my horse power isn't that great.
I put a higher compresion piston in a 450R, and it helped alot. The difference between $800 ans $125 is substantual, when looking for a little more power.
Old Sep 2, 2006 | 08:25 PM
2manytoys's Avatar
When you are looking at 30+ hp no 2hp gain is not much. Higher compression will give more torque but you need to change the stroke to get the advantage of hp gains. If just changing a piston would gain noticeable hp everyone would be doing it.
Old Sep 2, 2006 | 08:50 PM
The 400ex isn't 30 plus, its 27. You can gain power without stoke a crank.
Old Sep 2, 2006 | 10:26 PM
2manytoys's Avatar
I know you can add power by adding bolt ons, head work and stroker kit but just adding a piston will not give you much gains without doing motor work. I was useing 30hp as just a number. Not actual!
Old Sep 3, 2006 | 10:55 AM
TL450R's Avatar
if you get the higher compression piston it will help your power. and it comes with rings wristpin and bearing and circlips
