Master brake cylinder
Old Sep 5, 2006 | 08:23 AM
RABDAB's Avatar
Default Master brake cylinder
I have a 02 Recon and an 03 Rancher on both of them the front brake lever goes all the way in, even after I adjust the brakes. I was told it's a bad master cylinder. Can it be fixed or dose it have to be replaced ?
Old Sep 5, 2006 | 09:31 PM
ForemanDan's Avatar
The odds of both of them being bad are slim. More than likely you are not adjusting them correctly or the shoes are worn out. How are you adjusting them? Do they have brake fluid? Does the slave cylinder move on both wheels? Have you pulled the drums or are you adjusting through the "hole"? Did you adjust all 4 adjustment thumbwheels?
Joe454
Nov 20, 2020 01:19 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
